Anyone have a set or know if there even are any?
I have the lines and airports(?) installed. I'm just not sure if I can cut the existing lines to tap into them or if I need to air the system down first.
Plumbing the system seems pretty straight forward. I just would like to know what to expect when I do plumb it.
My plan is to tie into the lines fairly close to where they come out of the valve block but some printed out instructions I could reference would be great.
Thanks,
jastutte
You'll need to let the pressure out first (although cutting the pipes will let it out pretty quick anyway). Cut the pipes squarely with a sharp Stanley knife then chamfer the ends with a pencil sharpener.
Thanks. I'll get on it.
I was able to tap into the line going to the tank and refill it to 140 PSI.
I then turned on the RR and it quickly rose to normal height.
Turned it back off and topped off the air tank to get it back up to 140 PSI.
Thanks again for your help.
lightly armoured? is that like half pregnant? - are we talking about small arms, RPG or armoured piercing rounds?
yeah. it looks a bit goofy typed out that way.
but i wasn't sure how to describe what each vehicle had.
probably should have just said "lightly modded". though, then some may have asked what new software i had added to truck(s).
