Does anyone know where I might be able to get a Bosch MAF connector? Ideally with 6" or so of wiring.
Mine has a break in the insulation on the MAF signal wire (it has no cover like others, hence the 5 wires are exposed), so I'd like to lop it off and replace it to rule that out causing me some minor issues.
As it's Bosch I suspect it's going to be the same as a MAF connector on just about every other European car on the road. Local scrappy would probably be your best bet.
I've got a loom that I've butchered, drop me a pm with your address and I'll pop it in the post
Failing that, if you want a new connector, then I believe this is the same as the MAF uses...
5 Way Connector
Oooh that'd be handy Chris - I'll drop you a PM in a sec.
How do you find these things Marty? :) Searched for everything I could think of.
I found it awhile ago when I was looking into various connectors and the likes... Put a bookmark in to the company page as they also do OBD connectors which apparently are used in LR vehicles... and would be the first one I tried if I needed to replace an OBD socket on P38s..
