Finally got round to sorting the perishes vacuum hose and reconnected the actuator. Cruise works a treat!!!
Should there be a lamp in the instrument panel when it’s active? I know there’s one on the button on the dash but nothing to indicate it’s latched.
TIA
No.....
First car with cruise I’ve had that didn’t then!!!
At least it works, made light work of a motorway run yesterday.
You'll know when it's on, the light on the switch will be on and nothing will happen when you take your foot off the throttle.
Rover expects a higher standard of intellect from its operators. Ones that can reason that the vehicle is self motivating at a speed as requested fit into this category as opposed to those who view dash warning lights from a condom perspective (if it’s not on, it’s not on)!
