disconnected nearside headlamp wiper motor, kept running while ignition turned off, any suggestions please
You must have a short somewhere as it is fed with an ignition switched supply. Try pulling the relay (relay 11) and see if that stops it.
Thanks Gilbertd, that did the trick
