Any suggestions as to where to buy same at a sensible price.
Front or rear? Front https://www.lrdirect.com/STC2786-Sensor-Abs-New-Rr-Front/, rear for an early car https://www.lrdirect.com/STC2787-Sensor-Abs/, rear for later one, https://www.lrdirect.com/STC3385-Sensor-Abs/. Only differences are the lengths of the cables though, so you can use any if you don't mind cutting, soldering and heatshrinking the joins.
