OK guys,
Whilst ferreting under the dash today, I found this connector, all alone and floating free. It is the male end and was sitting on the plastic cable tray, driver’s side (RHS). It is the male end, I.e. plug. It has a yellow and a black wire going to it. The yellow, with considerable imagination, could possibly have a black tracer, but you would have to use your imagination to se it.
I couldn’t find a socket anywhere. The tail I found disappears into the afore mentioned cable tray.
I have been through the 97/98 ETSM several times and can’t find a two pin connector that has Y & B wires going to it, save for a couple that are plugged into a diesel in the engine bay.
1997, 98MY 4.6 V8 HSE.
Thoughts?
Connector
Bad pic of wires
It connects to a switch on the clutch pedal to shut off the cruise control on a manual gearbox version.
Ah! Many thanks GD
