P38
HI ALL, new to this so not sure how it works, anyone live in the langport Somerset area, drivers door dead, no window or mirror, got key code lockout, tried putting the code in but nothing, as the door is dead I don’t suppose it will take it, Dave
Keycode Lockout will clear after 30 minutes, what does the dash say then if you try to start the car? Or can't you get into the car (in which case, how do you know the window doesn't work?).
Dash first says press remote then key code, everything worked fine until the battery went flat, I’m assuming because the drivers door is dead it’s not excepting the code
Sounds about right. It needs the EKA but if there is a problem with the door outstation then nothing will be working on the door. Does the window and mirror work on the passenger door? Both front door outstations are powered from fuses 9 and 22, so if the passenger side isn't working either, then that would be the place to start. If the passenger side is working, try swapping the outstations over and see if the fault moves.
I’ve changed over out stations with no joy
So after swapping outstations, passenger side works but drivers side still doesn't? There's a connector at the end of the rubber tube between the door and the rest of the car inside the door jamb. Try tracing back and see if you can find that and check it for corrosion.
Continuing from your post on the dark side, pulling the sill locking knob up on either side won't do anything while it is out of sync and needing the EKA. The central locking has been disabled and until you find the fault with the drivers door and are able to enter the EKA, it won't be enabled again.
