Just wondering ---- vogue hazard switch is black ---- mates DSE switch is red ---- how come ---- red better so why mine black ? Anybody know ?
YUG102480 is listed for Vins from XA310482 and is the Black switch
AMR2691 is listed for Vins upto WA410481 and is Red
They obviously changed them, but I don't know if they can be swapped over or why they changed them.
Probably because the black looked better and as long as it has the red triangle on it, it'll meet type approval.
Can I swap to red one then ? are plugs same Red is easier to see quickly in an emergency I think
Looking at the face view of the plugs for the switches in the ETM, they don't appear to be the same. Same connections but different plug size.
Typical that is 🙄
I'm going to roverviews later for a switch and I will see if I can swap front of switch for red --- I'll update if possible to do -- just in case someone else wants to fit red instead of the black --- or vice versa
Went to roverviews and got red hazard switch and it fitted --- direct swap --- so now got switch you can see immediately 🤗🤗 thanks for info
