Is there a wiring diagram knocking around? I was a bit disappointed to not find one included in the workshop manual.
Thanks
?? There's a full electrical troubleshooting manual in RAVE, the workshop manual.
That's the GEMS version, both his cars are Thor and the wiring looms (and most of the wiring) are completely different. I've got the full UK CD of RAVE saved as an iso image file on my Google Drive. That is an electronic version of the workshop manual, overhaul manuals, electrical troubleshooting manual and owners handbooks covering the P38, L322 and Defender. Download it from https://drive.google.com/file/d/0BzxqPPypF5J5b1ZlU3RpMmVwanc/view?usp=sharing.
As an iso image file it needs to be burned to a CD and will then run directly from that by clicking the RAVE.exe file. I've always copied the full CD to hard drive and then run it from there it's much faster.
Here is a pdf copy of the 1999 onwards ETSM if it is any use.
99 Onwards ETSM
Thanks both. I spent out on the paperback version which doesn’t include the Electronics part 🤦‍♂️
Will look over the file version.
Workshop manual, overhaul manual and electrical manual are 3 separate volumes if you buy the paper versions but all are included in RAVE. I find it far easier to navigate than a 500 odd page book too.
Also because is a huuuuge wiring diagram!!!
Careful not to mix pre and post 99 diagrams (do NOT ask me how I know ...uf)
