Hi everyone,
Has anyone used a nano to re sync , and could run me through it , thanks
Yes, you need to go into Motronic and look at what the immobilisation code is. Take a note of it.
Then go into BECM and either 'other' or 'alarm' and find where it should be - it will likely be different. You can change it here though, enter the code you noted from Motronic. Then write the settings, disconnect, and it should start up.
