Hi, just a quick question - is this item with the two lenses the outside temperature sensor ? I have only just noticed it !!!!
It is in the lower grille under the front bumper.
No, looks like a laser speed camera jammer.
Hi Richard. I thought the same thing. I couldn't see it being a temperature sensor after looking up details for the temp sensor. It is completely different.
I thought it odd, as well, that it seems to have been moved a little bit at some time. I couldn't see that you would need to do that if whatever it is was an original factory-fit item. The copper bracket thing looks a bit Heath-Robinson !!
I will have to remove it now that I know about it because the "polis" in Ireland do not take kindly to the fitting of them. One could be fined €500 or more.
