Hello everyone,
Sinve I have had the car (1 year) I have to open and close the car with the key since the previous owner deactivated the alarm / remote system for whatever reasons.
Now I made most systems (except alarm) acive again but when I open/close the car via remote the driver door (LHD) does not open or close, all others including tailgate do.
I replaced the motor in the driver lock with one from a used rear lock, but that made no difference.
Opening/closing with key is fine. Sill switch works too.
Nanocom confirms that ajar switch works, cdl switch works and key switch works.
When I activate the locking mechanism via Nanocoms BECM / Outputs section I can also lock and unlock the driver door, so the motor must be working. BUT the functions are reverse, so when i activate the LOCK output, the door unlocks and vice versa.
Is that a Nanocom speciality like the way it confuses the blend motor sides left/right in the HEVAC section or is there an internal fault ?
Any advices are very welcome !
greetings,
Max.
No, the Nanocom gets it right, it only gets its left and right confused with HEVAC and, sometimes, ABS. It sounds like you reversed the wires on the central locking motor when you replaced it, so when it is already locked, it tries to lock it and when it is unlocked it tries to unlock it.
Brilliant ! That was it, finally wirks as it should....
Many thanks !
