Just bought some oil for the mrs car :(
use code oil50 to reduce oil by 50% at Eurocarpart.com
I got 5 litres for £12.49 which would normally cost about €50 here in France.
Likewise today at GSF
Code BLACKFRIDAY
When I was active on Ford Focus Owners Club they had a general purpose, all year round code for 25% off - unless there was already a better promotion active.
The code for that was FFOCUK25 but I'm not sure if it still works. I haven't used ECP for a while.
The Euro Car Parts discount code Blackfriday (valid until Monday) works but isn't as good as the one Paul has found. Just tried to order some oil for my car and the other half's Merc. Using the Blackfriday code, which claims to give 50% discount, didn't, it only gave 30% off. However, the OIL50 discount code did work and gave 50% off so if you want to buy some oil before tomorrow use that one.
The oil50 code doesn't seem to work on gearbox and diff oil :(
Just priced up a full gearbox, axle and power steering oil change with them and the BLACKFRIDAY code takes off about 33%
