Hi, I wonder whether someone might know where to find the correct wood finish fitted to their P38 ?
I know that the trim reference is on the build plate under the bonnet, but where would I find out the type of wood panels fitted ? I am assuming that my car has Walnut but I remember from having a couple of old Mercedes that making assumptions on the wood type and style was a big mistake as they made different colours of Walnut depending on the year.
Maybe someone has some ideas ?
how old is your rr pierre3 as I have a vin number checker I could pm you it should give you the wood type on there
Hi Karlos, my p38 is a 2001 2.5 DHSE.
just sent you a message mate
thanks karl
Thanks, Karl. I got your PM.
I'm pretty sure the '00 door cards i recently bought just said "wood" for the trim type on the label on the back of them. I also found my dash trim which looked totally different to the door trims had infact just been bleached by the sun, as when i removed it the area around the glove box button trim was the original dark color.
I've got a set of four door inserts if your needing a set as i transferred over my wrapped ones.
