It’s been a while since I last used my rangie, I’ve just put a new O2 sensor as I recall one wasn’t working, I’ll be buggered if I can find the settings on nano to check, could someone run me through it,, tia
Should be under P38 > Motronic > Motronic > Inputs > O2 for the sensor value (if you want to see what its reading now you have swapped it), If its logged codes would be a good idea to clear them from Faults as well (faults would be after the second motronic prompt)
