Hi All,
Good things come in twos .... my LPG installer now has a 1996 GEMS to do.
Does any good soul have any photos of a GEMS installation I could show him to help?
GEMS is much easier as it doesn't have that big bunch of bananas getting in the way. RH bank you can actually see the lower inlet manifold without removing anything. LH just needs the plenum lifting off. Most systems come with injectors in blocks of 4 which means the hoses to the back two cylinders on the LH bank can be a bit long. When (if) I ever change my singlepoint for a multipoint, I was thinking about using 4 blocks of two injectors so I can mount a block at each corner of the plenum chamber with the hoses being very short and dropping almost vertically downwards.
