Hello,
a sidekick of my EAS problems is this:
Nanocom tells me this:
in EAS/Inputs Menu: it does not say that the driver (LH) door opens. All others are recorded correctly. Therefore EAS continues to level with that door open.
in BECM/Inputs Menu: it records correctly that the driver door is opened (12V->GND). All others too. But the interior lights do not go on. But with the other doors.
How can that be?
Microswitch in door must be OK. And EAS ECU gets that info from the BECM, but the information is lost....?
greetings, Max.
RAVE says you can disable or enable the automatic interior light operation. Owners Handbook in the "interior" section.
Yeah, right, but the lights go on when I open any of the other doors.
Just not the driver (LH) door....
Strange. Will compare with mine later. At moment diagnostic socket is soaking in white vinegar to clean the corrosion. Was working a week or two ago, but now cannot connect to any ECU. 🙃 Been a bit damp in the air lately, & too much working from home.
