Gurus, where’s a convenient place to pick up a reversing light feed near the tailgate? I’ve found the loom coming from lower but all wires are white!
Thanks
Behind the LH rear light there is a 4 way connector that would be used if you had twin towing sockets or are fitting one of the modern 13 way trailer sockets. That connector has permanent live, ignition switched live, reversing light feed and ground. The reversing light feed is the Green wire and ground is Black.
Perfect, thanks for that. I’ll hook into that then!
Yes, that's where I connected mine and I've also used the ignition switched supply on the connector to install a couple of fag lighter sockets for plugging things in the boot in.
