I'm still learning the Motronic Nano, but I thought I'd post these just to show how bad things currently are:
Run 1:
NANOCOM - MOTRP38.APP - MOTRONIC fault file
PXXXX = PERMANENT VOLTAGE SUPPLY
FAULT DRIVE CYCLE A
OCCURED 1 TIMES
SIGNAL TOO LOW
FAULT IS NOT CURRENTLY PRESENT
FAULT DETERMINED AS PERSISTENT
FAULT DOES NOT CAUSE THE
MIL LAMP ACTIVATION
P1300 = CATALYST DAMAGING MISFIRE
MULTIPLE CYLINDERS DRIVE CYCLE C
OCCURED 49 TIMES
SIGNAL TOO HIGH
FAULT DETERMINED AS INTERMITTENT
FAULT CAUSES THE MIL LAMP
ACTIVATION
P0305 = CATALYST DAMAGING MISFIRE
CYL 5 DRIVE CYCLE C
OCCURED 45 TIMES
SIGNAL TOO HIGH
ACTIVATION
P1000 = CATALYST DAMAGING MISFIRE
CYL 7 DRIVE CYCLE C
OCCURED 29 TIMES
SIGNAL TOO HIGH
ACTIVATION
P1319 = MISFIRE WITH LOW/EMPTY
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
FAULT IS CURRENTLY PRESENT
ACTIVATION
P0134 = LAMBDA SENSOR UPSTREAM
CATALYST BANK 1 DRIVE CYCLE C
OCCURED 68 TIMES
SIGNAL INVALID
ACTIVATION
P0300 = EMISSION RELEVANT MISFIRE
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
P0305 = EMISSION RELEVANT MISFIRE
CYLINDER 5 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
P0307 = EMISSION RELEVANT MISFIRE
CYLINDER 7 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
P1000 = EMISSION RELEVANT MISFIRE
CYLINDER 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
NA
OCCURED 193 TIMES
SIGNAL TOO LOW
ACTIVATION
NA
OCCURED 193 TIMES
SIGNAL MISSING
ACTIVATION
NA
OCCURED 193 TIMES
SIGNAL MISSING
ACTIVATION
Run 2:
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
P0304 = CATALYST DAMAGING MISFIRE
CYL 4 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
P0303 = CATALYST DAMAGING MISFIRE
CYL 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
P0302 = CATALYST DAMAGING MISFIRE
CYL 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYLINDER 4 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYLINDER 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 6 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
P1674 = IMMOBILISER - INCORRECT
CODE DRIVE CYCLE A
OCCURED 193 TIMES
SIGNAL TOO HIGH
ACTIVATION
Run 3:
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 4 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 6 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CODE DRIVE CYCLE A
OCCURED 193 TIMES
SIGNAL TOO HIGH
ACTIVATION
Run 4:
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 4 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 6 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CODE DRIVE CYCLE A
OCCURED 193 TIMES
SIGNAL TOO HIGH
ACTIVATION
Run 5:
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 4 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 6 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CODE DRIVE CYCLE A
OCCURED 193 TIMES
SIGNAL TOO HIGH
ACTIVATION
Run 6:
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 4 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 3 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 2 DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
FUEL DRIVE CYCLE C
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
OCCURED 1 TIMES
SIGNAL TOO HIGH
ACTIVATION
CYL 6 DRIVE CYCLE C
OCCURED 5 TIMES
SIGNAL TOO HIGH
ACTIVATION
CODE DRIVE CYCLE A
OCCURED 193 TIMES
SIGNAL TOO HIGH
ACTIVATION
