Dear All,
Passenger door has decided to stay locked, nothing will free it, internal handle, locking tab, external handle, any other lock tab and remote. Allother doors operate correctly. Looking down inside I can see all the cables and rods are attached. So the latch must have failed. Question is how do you get the door open? The american forum suggests you have to remove the rear door and then butcher the metal hoop the latch locks onto.
Anyone got any other tricks or ideas?
See if you can see the horseshoe shaped bit of plastic that the interior handle connects to. If that has stuck at one end of the travel, you won't be able to open the door. If it has, poke it with a long stick so it sits central and the door should open.
