Just wondering if there is a better place to stick the aerial rather than on the heated windscreen, just in case the heated element interferes with the signal??
If you stick it right at the very edge on the passenger side, the elements don't go right to the edge of the screen. I fitted it there on our 4.0SE and it only drops out in the same places as mine (in a dip surrounded by stone houses next to where the step daughter works) with an amplified whip aerial on the roof.
Thanks Richard. Good to know. I’ll crack on 👍
I tried various screen antennas with little success. Even outside the heated area, I suspect the glass tint is not helping.
Now both my P38's have magnetic roof antennas which work really well. Eightwood DAB Antenna
That's similar to what I have on mine but with an external 20dB gain pre-amp. The signal still drops out in places, notably the M11 between Duxford and Stansted, but works well in most other areas. I expected the screen aerial to be pretty poor when I put it on the SE but as it came with the head unit I figured I might as well give it a try and it works far better than I thought it would.
where did you find the 20dB DAB amp ?? I've been searching for a 12V one.
One of these https://www.ebay.co.uk/itm/135066225960 but with the power via 3 diodes to drop the voltage and hence the gain. The only problem I have noticed with it is it suffers from overload so the signal drops out in close proximity to 5G sites. Been considering putting a 250 MHz low pass filter on the front of it but haven't got around to it yet.
Not sure if others noticed, but there were issues with several DAB multiplexes over the last two weeks across many areas in the UK. It was mainly the National channels. Arquiva had screwed up the service name data so the signals were not ETSI compliant. Tuners were missing about 40-60 channels depending on where people were located. Wierdly it only impacted USB DAB receivers. My Pioneer DEH-S720 worked ok.
Myself & several others on the DAB-Z thread on xda-developers emailed Arquiva, and eventually they fixed it yesterday morning.
