Sometimes I need to crank for a while until it fires up and sometimes not. Read somewhere that if it starts instantly when pushing the throttle pedal a little then it could be the iacv. That works. Sine they are amazingly cheap I thought of ordering one for testing that theory.
Do they need some kind of process where they have to be calibrated with diagnostic software or is it a simple plug and play procedure ?
Plug and play, just don't turn the ignition on with it plugged in but not mounted.
Perfect, thanks.
Change was easy but didn´t really make a difference, it still takes some time to start when the engine has been off for a while. I suspect the fuel pressure in the rail, will measure it.
