Seems a simple job but want to be certain.
Tackling another job (will check RAVE when home). My front propshaft snapped (maybe a seized VC). Now, my front differential is making noises - confirmed by a 4x4 mechanic. (I’ve done the tests for a seized VC, all good) So, I’d want to change the oil to see if that helps.
Anyway, I digress. It seems fairly simple. Is this correct?
Oil - 1.6L of 75w90
Syringe
Oil pan + magnet for any metal
Do I need new plugs?
TIA.
No for plugs.
Always take the fill plug out first. Only when that's removed successfully, then take drain plug out. Same applies for gearboxes, etc.
I hope you're lucky, but I think that once you're hearing noise new oil isn't likely to fix the problem.
