Evening guys,
I'm after a spot of advice...
I'm about to put a new gearbox into the DSE, however, with this being a 99MY it doesn't have the transmission dipstick fitted to it. From previous experience, it's much easier to fill the transmission and to check the level using the dipstick from above then it is using the fill plug on the side.
I've got a 1995 MY 4.6 breaker with the dipstick and tube still on it, is it possible to retrofit it to the DSE whilst the gearbox is swapped out?
Thanks!
David.
I don't know how the fillertube is connected to the oilpan versus the later fillerplug or else I should say swap the whole pan with dipstick if they are the same size.
