First electrical issue after 16k miles. Started the car and EAS fault arrived.
Right side is low, but the left is fine. Seems a hard fault. I remember using the EAS Unlock Suite. Is this cable fine?
https://ebay.io/m/ylaAXK
Let’s hope.
As I was about to type the above, I started the car and voila - error gone and the right side adjusted itself.
Now, when I first bought the car, it would end up on bump stops each time. To mitigate this, I park the vehicle at off-roading height, which has worked well for the last 16 months.
What’s the first step? Cable and software?
