I can't really understand why there's another thread and discussion on this now?!?  I asked these questions about stud torques in my engine rebuild thread and it was discussed there...
I mentioned in my thread that V8 tuner (who I got the studs from) recommended studs hand tight (I just 'nipped' them the tiniest amount with an allen key to make sure they were seated home), and then the nuts done up to 70lb/ft, done up in 3 stages, with a rest period of 20-30minutes between stages.
Mark, YOU yourself said in my thread that "70lb/ft sounds like a good number to go for"  I was taking the advice from the collective wisdom of the forum, as I'd never built an engine before... but now you're contradicting that and questioning a) ARP and their updated instructions, b) V8 tuner who told me 70lb/ft when I bought the studs, and c) yourself who agreed with it in my thread... but when it comes to your engine, it "might be a bit too tight, 65lb/ft is a good number"
Incidentally my engine seems to be running just fine at 70lb/ft..
With the amount of advice you input into my thread, I thought you were an expert at engines and these things, but it seems like when it comes to your own one there's indecision and second guessing at every turn.
                            '06 4.2 Supercharged Black/Cream "Jess" -- Bought April 2021 (NZ)
'01 4.6 Vogue Black/Lightstone "Snog" -- Bought Jan 2012
'99 4.6 HSE Cobar Blue/Lightstone -- Sold March 2009
'95 4.6 HSE Epsom Green/Tan -- Traded June 2008
