It just had to be done.......
Although that was on the way to mymysteri's house and I'm now at over 333700.
No point in ringing you at the moment then lol
No, cuz I've got work in the morning. Got home at 3am today.
Congratulations!
Did you get her sorted?
Yup, everything, even bunged a can of bumper black paint in the boot and was able to paint the yucky faded grey grille. The only thing left now is that the wheels need balancing as it gets a bit of a wobble on at around 90kph but I noticed that none of the wheels have any weights on them so that would explain that. It's now had a new drivers door latch, drivers window regulator, drivers door mirror, heater O rings, heater reconnected, keyfob receiver, tailgate gas struts, rear hub assembly complete with driveshaft and ABS sensor and a bit of percussive adjustment to a front ABS sensor. No warning lights, no beeping dash, everything works and it now drives as it should. Very strange getting out of mine and into a car that feels familiar but has the steering wheel on the wrong side and a diesel engine under the bonnet......
