Thanks guys,
Battery on removal was reading 4v!!! Fortunately seems to be taking charge and on last check was about 12v.
Will leave it on overnight and make do with this one until the car is running properly again.
The Hankook is a beast. After dicking around with re-charging and dealing with ABS/TC fault warnings on cold warnings I bowed to the inevitable and haven't looked back.
Thanks again guys, The flat one is now up to 13.1v and on trickle charge overnight. This would have been a real problem if it had happened when I was out, as I have to do the EKA Key every time to start it. I haven't had a chance to disable the Passive Immobilisation, but do carry a jump start kit just incase, but this time the car was very flat.
Will get the Hankook Battery next week I think.
Make sure you have some Weetabix before you lift it! lol
Thats ok the Caravan has a whopping 250aH Leisure Battery in it. Takes two people to fit it. Means we can go off grid for two weeks without charge.
Finally finished!
Rear Diff Large cog was missing three teeth. Drivers side rear hub had a seized bolt, yes the one that is almost impossible to get to. Had to file off the head of the bolt. Fitted Chris's Diff on the front, so had my old one here. Fitted that on the rear to get me on the road again.
Took for a drive and seems to be all good bit noisy over 55mph but then I have been driving a brand new car for three weeks. Tracking has worn out the front tyres so need to replace them as well as the rear diff. Might replace all 4 tyres and get laser tracking and alignment.
So...
2 Bump Stops
1 4pin Rear Diff
4 Tyres
Tracking and Alignment.
Ouch!
Just went outside to get the post and noticed the drivers side inside alloy had a score mark, it looked new. On inspection the lower part of the brake calliper has been rubbing the wheel! On closer inspection the lower bolt of the calliper is missing. I have had a hunt around for it and can't find it. Very unlikely I left it off as all bolts go in a pot. Annoying thing is its booked in for tyres and tracking on Monday. worried now the alloy is shot so the tyres might be a waste.
Currently it is parked over where I worked on it and it will not start again. Think the full drain on the battery the other week killed it. Going to get the kids next door over with their metal detector in case its still on the gravel/grass drive way.
That explains the noise you could hear, unusual for the Caliper bolts to come off, maybe one you missed, it happens,,
Just hoping it’s not on the M4 and it’s on my drive somewhere. Only place I seem to be able to get a bolt is online 1-2 business days or a breakers, therefor Monday.
Looks like another hire car!
This is the damage to the wheels...
https://ibb.co/m7WR7R
https://ibb.co/bMFVZ6
That's nothing to worry about, the wheels are damn thick in that area. Bolts are standard M8 so you should be able to find one anywhere.
Thanks, had someone offer me some 20” alloys and tyres for a little more then I was paying for tyres so might go with them anyway.
You might want to think twice about 20" wheels. You're likely to get a harsher ride due to smaller sidewalls, possibly tramlining too. Chris runs 20s and can probably feed back his impressions though.
Funnily its Chris's mate, Yes I am aware of the harder ride, If anything I find the P38 a bit soft, might be proven wrong! Not sure how larger wheels effect tramlining, yes slower acceleration and higher top speed! haha.
However mine needs two new front tyres, two alloys need attention, can get a set of wheels and good tyres for less then the cost of 4 tyres.
Edit: I found an M8 Bolt and with the aid of a M8 nut its now 35mm long like I think it is. Will order a few bits on Monday as needs two rear bump stops, Hub bolt and Caliper bolt.
Errm no. Because the larger wheels have lower profile tyres so the rolling circumference stays the same. No different to 16" wheels having 65 profile tyres and 18" having 55 so the rolling circumference, and hence the overall gearing, doesn't change
Yes true! Hadn’t thought about that.
It's the profile that dictates how they ride. My local Indie told me that you want 16s for comfort and 18s for looks and now owning cars with both I can see exactly what he means. The SE and Ascot, both on 18" wheels, give a noticeably harsher ride than mine on 16". I once drove a Range Rover Sport on 22" wheels and tyres resembling rubber bands, that was evil, you could feel every little ripple in the road.
Well I have searched high and low and can't find a bolt, its an M12x35 can get one ordered online tomorrow but will call garage which is doing alignment tomorrow and ask if they have a p38 there that I can rob one off. They are an Indy LR Specialist. Then get my insurance's recovery company too take me there. Worst case I keep the car off the road for another couple of days and wait for the bits, including new wheels and bump stops.
If it's M12 it will be one of the bolts that hold the caliper carrier to the hub not the smaller M8 that hold the caliper to the carrier. Not quite so easy to find as it's a fine thread too.
Yep, its that one with the fine thread, £1.25 online but not usually stocked so car off the road again next week. Does make me laugh though it needs a hub bolt on the rear at £1.50 I need to buy a pack of 10! yet when doing a propshaft you don't get enough! Who makes these rules.
