I recently replaced the little bits in the front door handles that wear out and cause them to stick/become stiff bit the passenger side one is still not quite right.
My girlfriend reports that it's getting worse and nearly needs two hands.
Will the handle from the passenger side rear door fit on the front door? They don't seem to wear out like the front ones and a used one should do the trick nicely if it fits.
Door handles are handed and a different part number front passenger to rears so probably not.
Yeah, I figured left and right were different hoped front and rear would match, for the passenger side at least.
Ah well, I'll chance a used front one then.
Where do you get the plastic parts that wear, the passenger side front is stiff to open and neither the front handles fully retract.
I take it you've read my pinned post titled:
Stiff door handles solved and painless?
Thanks, having a dead brain day. Read that a couple of weeks ago!
