While sitting behind the rangey at the weekend i noticed a rusty protrusion on the rear bumper. Closer inspection showed two rusty protrusions which turned out to be hanging out of the access holes underneath, that are there to let you undo the bumper.
I fished about in the hole, and this fell out:
Looked at the other side and sure enough, the same thing was hanging out of the hole on that side too.
Bumper appears to be very loose, so clearly these mountings have failed. But i'm unsure if its just the bumper itself thats rusted out, or if the chassis is knackered... Does anyone know how the bumper attaches and where those rusty nuts are likely to be from?
I would remove the bumper for a look, but the LPG filler is attached to it which makes it a less trivial task.
