Exhaust repaired with bandages or even a bean tin and a jubilee clip, isn't a fail or even an advisory as the only reasons for failure are a leak or insecure. If the note has a number in brackets after it, then it's an actual reason for failure, if there isn't a number, it's a manually entered comment.
All, or most, places do a test, fail it, then do the work then a retest, it makes there figures look good and there's no retest fee as it hasn't left the premises. I took my daughters acr in to have two tyres fitted and an MoT. Rather than fit the tyres and then test it, they tested it, failed it on tyres, then retested it. My local guy got a VOSA inspection and they were concerned about his high rate of passes. He was asked what he did if someone came in with a blown lightbulb (which is the most common failure but he seemed to never have any fails on blown bulbs) and he told them he just fitted a new bulb. He was told he should issue a fail, fit the bulb and then issue a pass.
All running perfectly on LPG
