Right, onto the next issue on the red VSE.
It has a Tartarini LPG kit fitted to it that was installed in 2005 when the car was 3 years old and had covered 37k miles at a cost of £2150 according to the invoice I have here. The owner, a local gentlemen, was a jammy bugger as there's also paperwork in the history file for an £800 rebate he got from the green energy trust for having the car converted!
Anyway, the system is 12 years old and had done almost 80k miles since installation. None of the service positions in the book have been stamped so I can only assume that it's never been touched since it went in.
The car will switch to LPG and it will idle OK but when sitting on the motorway at a steady speed the car develops a stutter the second you switch it over, as if it's being starved of gas. When trying to climb the hill on the single lane road to our house, on LPG there's no power there either, it slows down on the hills, and won't go.
First things first, I was going to order the filters for it and change them but on the several single point systems I've worked on I've never noticed the filters getting that filthy. I can't help but think that the vaporiser/reducer is probably going to be due for replacement. If so, do I need to replace it with a like for like one? If not, is there any particular one that people would recommend?
Any hints/tips/suggestions would be appreciated as I don't know very much about multipoint unfortunately.
David.
