yeh fair play if its plastic more care is needed. More stupidity from landrover when designing this car i guess! The older defender/disco arms just used steel cased metalastic bushes.
Continuing the reassembly i spent some hours on it yesterday and today.
Yesterday I stripped the passenger driveshaft and CV right down to component parts, cleaned everything up and reassembled. The boot on that side had been replaced before, and i wasnt convinced whoever had replaced it had cleaned the joint properly. I have a rule to always just replace the whole CV, instead of just refiting a new boot, for numerous reasons... Cleaning up old CV's is horrid, they're almost always worn anyway, and complete CV's arent usually that much more expensive... Ofcourse i ignored my own rule this time for some reason, and regretted it, as there were some pretty heavy signs of wear in the joint. But Oh well. It went back together with its new boot, though i did end up with absolute rage at the fixing bands supplied.
Most of the time, CV boots are supplied with Oetiker style band clamps like this, and as a result i have a set of the proper pliers required to set them:
And thats exactly what was supplied for the small end, as per the pic. However for the large end, they supplied this junk:
Not a clue what its supposed to be and completely useless. Luckily i had a couple spare "universal" types. Unfortunately they were intended to be used with rubber boots, and didnt like applying the clamping force usually needed for the plastic boots, first one i fitted i folded the tangs right back over on themselves with the clamping force... but i fitted them as best i could and hopefully they will stay on.
So with that done i got the new axle oil seals fitted, balljoints torqued and got the shaft and hub reassembled into the knuckle, brakes back on and ABS sensor refitted. So the passenger side is now all complete bar installing the wheel, and tightening the steering balljoints.
So this morning i started the same process on the drivers side... and ofcourse being a P38 it likes to throw curve balls! Removed the shaft from the hub and noticed the hub felt rough. Bearing seems to be completely shafted. Super notchy (feels like a stepper motor, snapping between poles!) and very rough sounding. Oddly enough never heard a peep from it when driving, but clearly i cant refit it like that.
Anyway i've dismantled the shaft and CV from that side, stripped and cleaned the CV and reassembled with fresh grease and a new boot. I guess its sorta stuck now until i get the hub bearing sorted. However after lunch i will go back out and finish tightening the steering balljoints, maybe refit the passenger wheel and see about sorting the nearside ARB droplink.
1994 Range Rover 4.6 HSE - Rough, but has an MOT!
2000 Audi A4 1.8T Quattro - Long term weekend car, 'slightly' modified...
2022 Skoda Enyaq - EV daily driver.
