I have an oil leak (standard fitment, of course) that I can't work out where is originating from...
The starter is getting covered in oil, to the point the frame rail immediately opposite it is getting wet, and the exhaust heat shield gets a build up that burns off.
The rocker covers are, for once, not leaking, and I've cleaned/degreased both sides of the engine since last doing them.
Looking up from underneath, the oil does not appear to be coming from the front of the engine, but about half way back, it suddenly is quite wet:
Front end is dry:
If it were the valley gasket at the back of the engine, I can't see how oil would make it this far forward? I'm also not dropping much on the ground, the odd drop. I think most is worryingly ending up being burnt off. I thought head gasket perhaps, but from what I can see there is only one oil feed up to the heads, and that is on the front end of the engine above the cylinders...
