Been trying to get the RL height sensor off.  The bottom nut undid OK but the top one didn't turn before smashing the plastic ear off. This means (as I'm sure many are familiar) with a nut secured to a bolt, which passes through the bracket and is neatly held on the other side by a plastic bushing so you can't hold it tight enough in pliers to stop the whole lot turning.
I can't get a hacksaw in there to cut through the bolt. I don't have a file to file some flats on the round flange at the back of the bolt.
What have you guys done in similar situations?
