Luckily not the 3 grouped together, the one out on it's own.
Drilled most of the old bolt out and thought right - let's see if an easy out will be able to complete this. Guess what? I applied my hand torque to it... SNAP. Bollocks!
So as usual these easy outs are too hard to drill out but not hard enough to be any use. I have thrown all those easy outs in the bin. Waste of time.
Any one have any sources of diamond tip drill bits please?
My motor works fine when it's cold but won't moved when it's hot, so I thought is check to see if the motor was clean and it is
