**Crossposted from Opening Time
Martyuk wrote:
Morat wrote:
It's longer than mine but there's honestly a lot of stuff there that you could knock off in pretty short order.
If you want to compare....
- Viscous Coupling (arrived yesterday)
- Nasty scratch/dent above rear left wheel arch. This needs proper surgery and probably a replacement door. Super annoying as she had great bodywork when I bought her.
- CD player just shows "Error"
- Sat Nav doesn't get a signal
- I think the mid speaker in the driver's door card is dead
She's drivable but I don't want to put any more miles on her until the viscous is replaced or it'll just wear out the front tyres even more and damage the UJs and diff at the front. I'm tempted to DIY but not that tempted. I'll need a prop tool and probably a gear puller.
3/4 probably mean "Android head unit" but that'll have to wait.
5 Yeah I should do that. One day.
I'd probably get a few more propshaft nuts... at least a couple of the new ones i put on at the back were already starting to round... even with the propshaft nut tool! The access to the nuts at the back is a PITA because of the angle it comes off at. You'll probably get another use out of them anyway, and they aren't done up stupid tight - but up to you... They're 3/8 UNF and an be had on the likes of eBay in packs of 10, probably cheaper than what a LR place would sell them to you!
Marty, I appreciate this post. I'm currently getting the Jeep through the MOT which needed tyres and is going to consume my spare funds (quite apart from Her Ladyship's Birthday and two weeks holiday!)
BUT, thinking about it:
I'll jack up one side this weekend and see how the rear propshaft looks. I know it's in better shape than the front was - but that's not saying much :)
For the front I reckon I'll need:
New nuts/bolts, a couple of litres of Dex III and some RTV should sort it.
On the tools front, I've already got a breaker bar with 1/2" end. I'll need a pumpy bottle thing (like this? https://tinyurl.com/y5cb4ohg) and a propshaft nut tool which seem to be available from most LR sites in 1/4 and 1/2" drive.
Some say you need a gear puller to get the viscous unit out but Marty reckons some wood and careful hammering should be OK.
I've seen mention of a bearing that needs to be swapped over, not sure about that one..
I'm off this weekend but only because it's a busy one for the family. I'll probably start stockpiling the parts and have a go next month.
2001 4.6 Vogue. Epsom/Lightstone.
Suspension Calibration blocks available for loan (home-made but seem accurate)
Nanocom for P38/Motronic available in York/Scarborough area.
Currently on the list:
Back to the boring perma-list:
Driver's door latch. Sat Nav is lost. CD player U/S.
