It certainly sounds like a glow plug problem. Clouds of black smoke means unburnt fuel.
There is a relay for the glow plugs (and an 80 amp fuse built into the relay), located in the ECU box at the back of the battery.
You can test the glow plugs in situ with a multimeter to see if power is switched on to them when the bulb is lit.
Check the tracks on the relay to see if there is any corrosion or burning.
2000 Range Rover 2.5 DSE HP24 auto, uprated torque converter - JFearn chip, larger intercooler, removable winch, stainless exhaust, alloy radiator, Gen III's, Terrafirma +2" shocks, GG AT2/3's.
Full Fat Faultmate able to do all models.
- ex 1996 Discovery 2.5 300Tdi diesel auto
- ex-1982 Classic 3.86 Perkins diesel manual
