Top hose shouldn't get warm until the thermostat opens.  The procedure in RAVE is a bit simplistic.  My way of doing it is to disconnect the top hose and fill the engine block through there.  When that is full, reconnect it and fill the tank.  With the bleed hose from the top of the radiator disconnected, squeeze the top hose, plug the nipple on the radiator with your finger and release the top hose.  This will blow air out of the nipple and draw coolant in from the tank.  Keep doing this (and topping up the tank) until coolant flows from the nipple then connect the pipe to the tank (after blowing through it first to make sure it is clear).  Then carry on squeezing and releasing the top hose but plugging the little hole just inside the tank filler neck to continue blowing air out and sucking coolant in.  Once you are getting a constant stream of coolant through, give the hose a few squeezes and listen for any gurgling or bubbling anywhere.  If you can hear any, there's still air in there so start the engine, let it run for 20-30 seconds and switch off.  That should move any air around and let you bleed it out.  Once there's no gurgling noises, then start the engine.  With the tank cap off, let it idle and check the hoses.  The first hose to start getting warm should be the one from the inlet manifold to the heater.  Make sure that is getting warm and shortly afterwards the return from the heater should start to get warm too.  Some coolant may come out of the tank due to simple thermal expansion, but it will just be a small dribble, not a volcanic explosion and definitely not with any bubbles.  Run for a short time until you can feel the top hose getting warm.  Switch off and let it cool down
Top up the tank if it needs it and put the cap on.  Let the engine run and feel the hoses.  The top hose will get hot and will get firm.  It'll be firm, not rock hard if you've got all the air out.
- '98 Ex-Greater Manchester Police motorway patrol car, Range Rover P38 4.0, in Chawton white - the everyday car
