After Summer Camp, I asked Marty about some of the things that he could sort on my (my wife's) Range Rover and we set a date for last weekend. It turned out to be quite a busy time... for Marty at least :)
A lot of my original list is now gone!
The heated seats now work, and have the uprated 50degree thermostats, which are very popular.
The HEVAC unit now shows all of its pixels. Also, it is LED illuminated which doesn't quite match but is very clear and pleasant to look at.
The drivers door lock was replaced - I knew the switches were dead because I couldn't enter the EKA the first time I got locked out. This forced me to buy a Nanocom (which I don't regret) but now there's a new door lock which even has superlocking.
Then when we were scratching our heads and watching the EAS go up and down, we realised that it was still going up and down with the passenger door open. Duh.. shouldn't be doing that! Another door lock solved the problem, there's something eating microswitches round here :(
The EAS was a complete bastard. Marty was flicking through the circuit diagrams at ludicrous speed but the only thing that stood out on the Nanocom was that the Hand Brake on/off input was always showing ON. Weird. There wasn't any known reason why that would make my EAS only ever go up but it was definitely a fault so it was worth fixing. Frankly confidence in the vehicle was quite low. Driving at 70mph and finding yourself in High Centred mode is not very pleasant because the thing handles like a baby Giraffe on the first corner.
Marty narrowed the fault down to the Pink/Black wire which runs between the BECM and the EAS ECU. We were running short on time so Marty disconnected it and I tested it on the way back to sleep that night. It worked! For the first time in ages the Rangey dropped to Motorway height when it was meant to. The only downside was that without the handbrake signal, Access Mode isn't possible. We did toy with the idea of leaving it like that but neither of us would have been happy with an unsolved mystery.
The next day, when he started to trace the wire, he found the end of a self tapping screw coming up from underneath the vehicle into the wiring loom on the right hand side ahead of the BECM.
Great. Some soldering and shrink wrap later there were four wires repaired (including the handbrake wire) and full EAS was restored. RESULT! sadly we then wasted a couple of hours because of faulty LR manuals which indicated that the handbrake signal was still incorrect. I got to see inside my own BECM (which is a bit like watching your own open heart surgery) but eventually it was certain that the BECM was working fine.
That cost us the chance to have a go at the faulty blend motor, but by that time it was clear that I've got bigger problems behind the dash. The carpet under the drivers footwell is soaking and pink. Uh Oh. I guess that means the dash is coming out pretty sharpish* for a new heater core, so the blend motor and a sensor can wait till then. Hmmpph :(
In other bodging news, Marty took the chance to change some bulbs in the instrument cluster. The ABS and TC bulbs were fine.. just taped over by some previous MOT dodger. Great.
Then to top it, on the way back a new and expensive sounding noise appeared from underneath. It could be a CV joint... I should find out tomorrow.
But massive thanks to Marty for putting his brain to work on The Duchess, which is now a far more complete motor than it was before. I hope we'll be able to get one of his Audi heater cores in it some time, but I think I'd better investigate the running gear before taking any more motorway trips.
*sharpish is realistically a couple of months. Lets hope nothing goes badly wrong by then.
