Moving on to the front cover which came back from the vapour blasters with the oil pressure relief valve in bits and parts missing.
Many thanks to Turner engineering for a replacement piston.
Looking at the oil pressure by pass valve there is a hollow tube within the spring should there also be one on the bypass valve?
