The only place for a coil spring is up Zebedee's arse.
Moving on to the front cover which came back from the vapour blasters with the oil pressure relief valve in bits and parts missing.
Many thanks to Turner engineering for a replacement piston.
Looking at the oil pressure by pass valve there is a hollow tube within the spring should there also be one on the bypass valve?
One should have the insert, the other shouldn't, from memory of taking one apart last year.
Thanks Miah,
just what I needed to know.
Regards,
David
