EAS software doesn't give me the "good idle"
and it keeps flickering green and red...
The car is also sitting pissed again, and i can't adjust it!!
piece of shyte.
piece of shyte.
Go into Comm Port advanced properties in device manager and change the maximum data rate to 4800 baud. That should sort it.
Cheers Richard...
Didn't seem to do anything
What computer are you using, what operating system and are you using a USB adapter. If so, does it have the FTDI chipset or Prolific?
Hp laptop with windows 10..
As for the chip, i have no idea Richard, is there a right and a wrong?
FTDI just work, Prolific might work sometimes but are well known for dropping the connection when they feel like it. In Device manager, under Ports, you should be able to look at the driver manufacturer which should tell you. I've never actually tried to use any serial comms under Win 10 I'm afraid, I know they work faultlessly under Win XP but normally I just use a very old laptop with a serial port running Win 2000.
