Thanks Marshall, that was actually job #1 soldering the Blue/white and Blue/Pink wires back together.
So..........
I could not face tearing out the centre console of Bolt yet again, so I trundled over to the local breakers yard where they have had an 98 for about 18 months now.....Not much good left at this point.
Got both the height switch module and just for fun, the inhibit switch both for 10 bucks. Got Lucky!!
Got back, cleaned the grime off the adjuster and plugged it in.......Instant gratification!
As you have observed, Gilbert, there is a bunch going on inside that module. It does a self test of all 4 leds on Ign on, then settles down to the correct spot. It also appears that the Binnacle display may be driven by it as well since in testing, whenever the top LED is on, no matter what else is on, the binnacle symbol comes up as well.
Now, to go out and put all wires and trim back, after giving the sill channels a good clean of course!
The compressor is still doing odd short cycles, but that is gonna be tomorrows job!
In all, I found the delay relay failed, the EAS controller is dodgy as it shows inhibit at all times, There was a serious leak at the front most tube collet on the valve body, and, of course, someone got clever with the switch module....destroying it!
All up, it is ~almost~ understandable (If totally inexcusable) that the PO put on springs.......
Total out of pocket to put it back? $227.00 and about 8 hours total labor. The worst part was removing the stupid springs without a proper tool!
Anyone wanna buy a set of slightly used OME springs? Cheep!
Thanks for the help!
Cheers,
Tom
I seem to be stuck on British machinery:
2002 4.6HSE "Bolt" - First P-38 Most reliable car I have owned. Go figure?
2002 4.6HSE Borrego Edition. Back on air and loving it! (Now moved on to a new caretaker)
2000 4.6 HSK "Fang" Wife's daily driver. all original
2002 4.6 Borrego Yes, another yellow one, but with SD rack and factory winch!
1985 Classic with Tdi300 Diesel conversion "Outback special" Australia
1982 Waveney Class Ex RNLI Lifeboat
1952 Austin Champ (My first car in 1975) Hawaii
1953 Austin Champ Just for fun! Australia (Sold to mate in Vic)
