It's also 3 points per tyre here, where 12 points is a driving ban :O
I've had them swapped front to rear and had the tracking done. I'll see how they ex-rears wear over the next few hundred miles and get a new set.
I'm a bit sad they don't make that pattern anywmore as they're a nice compromise for wear, all season performance, offroading and price - but I guess things move on. I don't really want to put an aggressive looking tyre on a P38.
Front Left, apart from being underinflated, was also much more worn on the outside shoulder, whereas the Front right was worn on the inside shoulder - and the difference between the shoulder and the centre of the tread is over 4mm depth so it's quite a severe gradient. That's on the correctly inflated tyre :(
2001 4.6 Vogue. Epsom/Lightstone.
Suspension Calibration blocks available for loan (home-made but seem accurate)
Nanocom for P38/Motronic available in York/Scarborough area.
Currently on the list:
Back to the boring perma-list:
Driver's door latch. Sat Nav is lost. CD player U/S.
