Hi guys,
Been making some progress on getting my car moving again - working on the front axle 'refurb'.
While doing that, I was undoing the back of the OS radius arm and had a closer look at the EAS tank. It looks more than a little 'crusty', with maybe, some pitting.
With the axles/hubs I've found that a hammer and chisel is an effective way of removing the rust and it seems simply that corrosion has got in underneath the original paint.
I guess this could be the same - remove it, clean off the rust, prep and paint - but it is a pressure vessel.
What do you guys think with more experienced eyes? At the moment the system is drained down to change the front bags, so a good time to pull this out.
Thanks as usual
