Can the rear brakes be bled on their own with satisfactory results or is it best to do the whole system?
When I changed all my brake callipers couple of years back the rear flexi pipes obviously weren't coming undone so i kicked the can down the road and left them as still being functional.
The metal extension on one rear caliper pipe let go last Monday so I've been dodging the rain for the past couple of weeks of spare time getting things changed. Which included making new sheet metal brackets ANR 5918, ANR 5919 and the "flat with a  slight bend one at the bottom" which, apparently has no part number. Searching the usual supplier suspects indicated that availability of ANR 5918 & 5019 appeared to be spotty with daydream prices on some suppliers.
So I drew them out and made a set of four. Drawings can be sent as a pdf if anyone wants them. Not intrinsically hard to make but something of a PIA to mark out and cut to size making for a slow job. I officially have too many toys, including a 41/64 th drill for the hose hole, so getting it done merely took longer. Cutting the blanks would have been an ideal job for the baby CNC mill I've never worked up enough enthusiasm to get going.
Further searches after the event suggests you can get ANR 5918 & 5019 for £5 - £10 each if you choose suppliers wisely but no one seems to have both.
