v8vroom wrote:
What concerns me is that my car does not display “oil pressure low”, yet the dipstick shows nothing. It doesn’t help that the car was on a minuscule incline, but the engine was cold for an hour, so I’m not sure what to trust.
There is no display for Oil Pressure Low, only the light, and if nothing is shown on the dipstick, you've got no oil in it!! It should show between the two notches, the top one being Max and the bottom one being Min. Any less than that and I am not surprised you have tappet rattle. The oil is circulated around the engine so once the top end is being lubricated and the hydraulic tappets filled, you've got nothing left! Fill it up to the Max notch. What oil you use is pretty much irrelevant if you don't put enough in it.
The only time the "oil pressure low" light illuminated was when I was going downhill and taking a roundabout at a bit of speed. Never has it come on since.
That's because you have very little oil in it and a combination of downhill and turning meant there was nothing left in the sump for the oil pump to pick up. Keep running it like that and you will very soon be looking at another engine rebuild.
It also doesn’t help that the previous owner didn’t include a temperature sensor when upgrading the header tank, albeit being a better material.
There never was a temperature sensor on the header tank, the temperature sensor is on the top of the inlet manifold. It is two sensors in one housing, one to feed the engine ECU (the temperature you see from OBD) and one to feed the temperature gauge on the dash.
Thanks, this makes a lot of sense.
Why I assumed the car had no "temperature sensor" is because it was aftermarket and the needle would start from 0 and stop just before "half", so I assumed it was not operating as standard. That is somewhat reassuring - knowing the car itself was not overheating. I've ordered oil today, and to my surprise, it will be arriving tomorrow. I'll gradually fill it up on flat ground and use the dipstick as a measure of where to stop.
I should note, the tappet sound was there when purchased, and when my mechanic had inspected the car, so not a direct link to low oil.
1999 4.6 V8 Autobiography Java Black LPG - 101k - 2022-2024
2001 4.6 V8 Vogue Oxford Blue LPG - 204k - 2025 -
