Come on, pull up a stool and get yerself a fresh pint...
So, it's brake blitz time.
I've got the modulator modification, I'm having a part made to modify the PCRV and I'd already got a stainless hose kit from Goodridge.
As I'm still waiting for the PCRV bit I thought, let's drain the fluid and do the hoses first, then I'll be dealing with an empty reservoir. Good idea, huh?
Well not really. Y'see the bloody hoses don't fit, or at least 4 out of 6 don't fit, to be precise. Goodridge advertise their kit as being for 1995-2001 Range Rover P38 UK and European spec, so, strangely, this is what I ordered and what it says on the packaging...
However, as you'll see, it's not quite so...
Hard line to rear caliper
Intermediate hose over rear diff
The front pipes appear to be correct and no, they haven't just mixed up the fittings. if you were to swap them, the new hoses would be too short.
I sent some earlier (not as clear) pics over to Goodridge two weeks ago and their first response was that I should sent them my old hoses. I argued that as they sold, and I paid for, the kit as fitting my vehicle, perhaps they'd like to send the right one instead. This elicited the following reply on January 27:-
_" Unfortunately I don’t have the hose details for your car (huh?) and I’m going to have to ask you to supply some information with regards to what you require to make this work
As originally stated the best option is to send us your hoses to copy but I do appreciate the expense and difficulty in doing this
It clearly states on the website that these hose are for UK/European vehicles only and I cannot comment on any changes made for cars sold in the Philippines."_
So apparently, not only do Goodridge not have the details for my vehicle, despite advertising and packaging them as such, I've got some weird one-off that Land Rover Special Vehicles produced specifically to send to Manila, where no-one could afford it.
My next response was to send a copy of the build sheet which states very clearly that the vehicle left Solihull and its next port of call was to be Land Rover France (note, NOT Land Rover Philippines!) so sounds pretty Euro spec to me. Along with this I sent a copy of the relevant page from the Workshop Manual showing, strangely enough, exactly the same layout as mine has...
I also sent the pictures above.
Since then, I have had only silence, reminiscent of a certain doctor who has had 250 of my dollars for two years now and from whom I also have no parts.
Problem I have is that it will cost around 150 quid (I checked) to courier my hoses, back to the UK, with no promise that this will make any difference whatsoever. At least now, if push comes to shove, I can re-fit my old hoses and struggle on with them for a while. Can't do that if they are winging their way to the UK now, can I?
Trouble is,until Goodridge actually admit that what they have sent is not for a European Spec 1995-2001 Range Rover P38, we can't progress, and the silence is deafening on that one.
In three years and several thousands of pounds of stuff shipped, I've only had one instance of wrong parts and a single e-mail was all it took for Rimmers to immediately rectify the matter, with no argument and not even a request for me to return the wrong bits. Just good old fashioned customer service. Not Goodridge, oh no.
Let's see if this week brings any movement, but just be aware if you are thinking of ordering any.
