Happy new year all.
Advice please. Went out to the RR yesterday turned the key and the sat nav screen is white. Wasn't like this the last time I used the car. I assume it's the CD player unit in the boot that's decided to give up. I have tried a different disk on different. Radio/cd is working fine. I read somewhere that when this happens it can mute the volume? Any help much appreciated as always.
Rob.
Hmmmm, white screen of death is never good, if the dsp amp had gone then it normally does mute the volume, so you might be lucky and it’s just the driver
Well what do you know. Sat nav is working fine today came on as soon as I turned the key all the inputs wook as they should and it's showing the correct location on the map. P38s don't you just love them.
Rob.
If you find yourself in need of a sat nav screen I have the one I took out of mine when the DSP amp died.
The sat nav worked fine, I just lost all audio as Chris said.
I've got a copy of OB's disk - but very soon after I started using it my satnav lost the ability to remember where it is. I'm not sure if it's the disk or the antenna - I suspect the almanac data isn't right but maybe it's just me.
I should be able to dig out the iso if you like.
